Tidied up code
#picaxe 28x1
setfreq m8
' humidity translation table
TABLE 0,(0,55,0,83,0,110,0,138,0,165,0,193,0,221,0,249,1,21,1,49)
TABLE 20,(1,77,1,105,1,133,1,161,1,189,1,218,1,246,2,19,2,47,2,76)
TABLE 40,(2,105,2,134,2,163,2,192,2,221,2,250,3,23,3,52,3,82,3,111)
TABLE 60,(3,141,3,170,3,200,3,230,4,4,4,34,4,64,4,94,4,124,4,154)
TABLE 80,(4,185,4,215,4,246,5,21,5,51,5,82,5,113,5,144,5,175,5,207)
TABLE 100,(5,238,6,13,6,45,6,77,6,108,6,140,6,172,6,204,6,236,7,13)
TABLE 120,(7,45,7,77,7,110,7,143,7,176,7,208,7,241,8,19,8,52,8,85)
TABLE 140,(8,119,8,152,8,186,8,220,8,254,9,32,9,67,9,101,9,135,9,170)
TABLE 160,(9,205,9,240,10,19,10,54,10,89,10,125,10,160,10,196,10,232,11,12)
TABLE 180,(11,48,11,85,11,121,11,158,11,195,11,232,12,13,12,50,12,88,12,125)
TABLE 200,(12,163)
symbol SCK = %11111101
symbol SCK_PIN = 1
symbol DAT = %11111011
symbol DAT_PIN = 2
symbol NDAT = %00000100
symbol t_in = 3
symbol h_in = 5
symbol my_trisc = 0x87
symbol relay = 0
symbol halfclock = 10
symbol fullclock = 20
symbol zero=4010
symbol transfer = b0
symbol checkbits = b1
symbol wordlow = b2
symbol wordhigh = b3
symbol wordcalc = w1
symbol humirawlow = b4
symbol humirawhigh = b5
symbol humiraw = w2
symbol temprawlow = b6
symbol temprawhigh = b7
symbol tempraw = w3
symbol itemp=b8
symbol humidity = b9
symbol dloop = b26
symbol scratch = b27
gosub setup
gosub connectionreset
cycle:
gosub measuretemp
gosub measurehumi
debug
wait 18
goto cycle
end
setup:
peek my_trisc ,scratch
scratch = scratch & SCK ' set the SCK as output
scratch = scratch | NDAT ' set DAT as input
trisc=scratch 'clock under my control
low portc SCK_PIN ' force clock low, data is externally control
datout:
scratch = scratch & DAT ' set the DAT as output
trisc=scratch ' use the external pullup to set data high, clock under my control
datin:
scratch = scratch | NDAT ' set the DAT as input
connectionreset: ' routine to reset the chip
for scratch = 1 to 10
high portc SCK_PIN
pauseus fullclock
low portc SCK_PIN
pauseus fullclock
next scratch
gosub transstart
transstart: ' routine to start a transaction
low portc SCK_PIN: high portc DAT_PIN' clock low and data high
pauseus halfclock
gosub datout ' set the clock and data as outputs
high portc SCK_PIN ' clock high and data high
pauseus halfclock
low portc DAT_PIN ' clock stays high, data low
pauseus halfclock
low portc SCK_PIN' clock goes low, data stays low
pauseus fullclock
high portc SCK_PIN ' clock high, data stays low
pauseus halfclock
high portc DAT_PIN ' clock stays high data high
pauseus halfclock
gosub datin
readbit: ' generate a clock pulse to read a bit into b1
pauseus halfclock
high portc SCK_PIN ' set clock high, data stays high
pauseus halfclock
checkbits=pins & NDAT
pauseus halfclock
low portc SCK_PIN' set clock low, data stays high
pauseus halfclock
writebyte: 'outputs the byte in b0
low portc SCK_PIN: high portc DAT_PIN ' data high and clock low
gosub datout ' set the clock and data as .outputs
if bit7=0 then: gosub clocklow :else gosub clockhigh: endif
if bit6=0 then: gosub clocklow :else gosub clockhigh: endif
if bit5=0 then: gosub clocklow :else gosub clockhigh: endif
if bit4=0 then: gosub clocklow :else gosub clockhigh: endif
if bit3=0 then: gosub clocklow :else gosub clockhigh: endif
if bit2=0 then: gosub clocklow :else gosub clockhigh: endif
if bit1=0 then: gosub clocklow :else gosub clockhigh: endif
if bit0=0 then: gosub clocklow :else gosub clockhigh: endif
gosub datin ' sets data back to an input
gosub readbit
readbyteack: 'inputs a byte to b0, send ack
gosub datin
transfer=0
gosub readbit:if checkbits!=0 then: bit7 = 1:endif
gosub readbit:if checkbits!=0 then: bit6 = 1:endif
gosub readbit:if checkbits!=0 then: bit5 = 1:endif
gosub readbit:if checkbits!=0 then: bit4 = 1:endif
gosub readbit:if checkbits!=0 then: bit3 = 1:endif
gosub readbit:if checkbits!=0 then: bit2 = 1:endif
gosub readbit:if checkbits!=0 then: bit1 = 1:endif
gosub readbit:if checkbits!=0 then: bit0 = 1:endif
pauseus halfclock
low portc DAT_PIN
gosub datout
gosub clocklow
gosub datin
readbyte: 'inputs a byte to b0
gosub datin
transfer=0
pauseus halfclock
gosub clockhigh
clocklow:
low portc SCK_PIN: low portc DAT_PIN ' set data low
pauseus halfclock
high portc SCK_PIN ' set clock high, data stays low
pauseus fullclock
low portc SCK_PIN: low portc DAT_PIN 'set clock low, data stays low
pauseus halfclock
clockhigh:
low portc SCK_PIN: high portc DAT_PIN ' set data high
pauseus halfclock
pauseus fullclock
low portc SCK_PIN: high portc DAT_PIN ' set clock low, data stays high
pauseus halfclock
waitcomplete: 'put timeout code in here if required
pause 20
scratch=pins & NDAT
if scratch !=0 then goto waitcomplete
measuretemp: ' read raw temperature data into tempraw
gosub transstart
transfer = t_in ' set measure temp command
gosub writebyte
gosub waitcomplete
gosub readbyteack
temprawhigh = transfer
gosub readbyteack
temprawlow = transfer
gosub readbyte
if tempraw> zero then
tempraw=tempraw-zero
wordcalc=tempraw//100
wordcalc=wordcalc/10
itemp=tempraw/100
tempraw=zero-tempraw
itemp=tempraw/100
measurehumi:'read raw humidity data into humiraw
gosub transstart
transfer = h_in
gosub writebyte
gosub waitcomplete
gosub readbyteack
humirawhigh = transfer
gosub readbyteack
humirawlow = transfer
gosub readbyte
for dloop=0 to 200 step 2 'lookup the raw humidity value in the table
readtable dloop,wordhigh
scratch=dloop+1
readtable scratch,wordlow
if wordcalc>=humiraw then: exit: endif
next dloop
humidity=dloop/2
