Jeremy Leach
Hello all ...long time no post
Fiddling around with background receive on a 28X1. Leg17 (Input 6, also serTx) I was originally using as a switch input before trying background receive.
I then run the Hsersetup command in order to start background receive - and it all receives fine.
BUT ...I then realise that Leg17 is now set as an output. I'm assuming that by issuing the Hsersetup command that leg is automatically configured as the hardware serial output regardless of whether it's going to be used to transmit or not.
Is this correct? And is there any way of keeping it as a switch input while using background receive? I doubt it, but just asking.
