28X1 readoutputs b0 vs let b0 = outpins
These two alternate forms of code for testing the outputs should be the same.
However, in the simulator, the first does not change b0 in the display nor does the If test respond.
Is this just a simulator issue or does the let b0 = outpins command not function at all?
Assuming it does work, what is the advantage of using this form of command over readoutputs?
#picaxe 28x1
high 2
let b0 = outpins
If bit2 = 1 then
sertxd("output 2 On",cr,lf)
EndIf
#picaxe 28x1
high 2
readoutputs b0
If bit2 = 1 then
EndIf
