AlexanderB
well for my A Level DT project i need to have 12 outputs not the standard 8 on a picaxe, so i turned to the 28x1 as it has the extra "portc outputs" but i've come into a bit of issus with writing to the outputs.
currently i have the standard output pins being writen like
which form the understanding i've been taught will put outputs 0,4,6 & 7 high (correct?)
so in theory could you use
to put the outputs 0,4,6 & 7 on Portc to high, or would that just change them to be outputs. (or is that the samething?)
I have read the bit in the PICAXE manual about it but i found it slightly confusing.
cheers for your help
let pins = %11010001
let pinsc = %11010001
