retepsnikrep
I have searched and looked at various post on this issue but my specific questions is this.
Can I use Outputs 1 and 4 for seperate HPWM outputs running the same 5khz frequency but with different variable controlled mark space ratios from 0 to 100%?
I have various outputs on the other designated Output pins so I don't want to disturb those, the hpwm masking code is a bit confusing can someone please show me an example for the above?
I don't want to use the pwm pins 1 & 2 on the Input side.
Thanks Peter
Thanks Peter
