28X1 beta library
Attached is the file required to add 28X1 functionality to a registered version. It is still in beta format at the moment, the main restrictions being:
1) background i2c and hserin receive are not supported
2) hpwm not supported
To install the file
1) Download the attachment
2) Under some versions of windows (with enhanced download file protection) you may need to right click on the file, select properties and click the 'unblock' button
3) Rename the downloaded file to AXEVSM1.DLL (its only called .DSN because the forum does not accept .DLL files as attachments!)
4) Copy the file over the original file with the same name in the \PICAXE VSM\MODELS installation folder.
