I have problems with OWOUT and picaxe 28x1 chips. Whenever OWOUT is called, the chip pretty much resets istself.
Readtemp has no issues.
Below is the code and output from sertxd
======= Terminal window: -=============
START-readtemp
T1=21
Main Loop
1START-readtemp
T1=21
Main Loop
1START-readtemp
T1=21
Main Loop
1
as you can see, the program never reaches the "owout sent" line. Another intersting thing is that the OWOUT outputs a "1" to the serial port. I have a LCD connected as well, that also receives data at that time. Though it shouldnt!
Any ideas? I thought the chip was busted, but replaced it with another one without any success.
I run everything on a picaxe experimenter board, so connections should be solid and clean.
SERtxd ("START-readtemp",13,10)
readtemp 1, b0
PAUSE 750
SERtxd ("T1=",#b0,13,10)
pause 100
sertxd ("Main Loop",13,10)
owout 1, %1001, ($CC,$44)
sertxd ("ouwout sent. Waiting",13,10)
pause 750
sertxd ("Wait over",13,10)
owout 1,%0001,($CC,$BE)
owin 1, %0000, (b0,b1) '
START-readtemp
T1=21
Main Loop
1START-readtemp
T1=21
Main Loop
1START-readtemp
T1=21
Main Loop
1
