afb
Hi ya
I'm using a 20X2 which processes various RC input signals, reads a couple of pots and three jumper links, has several digital outputs and also gebnerates a single PWM stream.
Having designed and built a strip-board layout I wrote some trivial test programs to exercise the hardware before starting on the programming proper. The bits all worked in isolation.
All was going well until I found one of my (previously tested) jumper link inputs had frozen into the low condition (it's normally pulled up by a 47K resistor, and the jumper, if fitted, links it to 0v). After some effort I have determined that invoking the HPWM command is responsible for pulling it low.
To eliminate my software application I wrote the following program
high B.7 'turns the LED on - just so I know its working
pause 3000 'time to see input C.0 (leg 10) is sitting high
hpwm 0,0,%0100,100,50 'I'm using HPWM C (leg 7)
do 'prevent HPWM terminating
sure enough after 3 seconds leg 10 takes a dive to 0v. The PWM on leg 7 runs just fine. I've even bent the entire HPWM set of legs out of the socket and C.0 is still pulled low.
Any ideas????
Any ideas????
