davecarter
I am reading a pulse width from a hall sensor. The idea is that i will recieve two pulses form two motors and control two servos. Which will follow a further pulsin from a rc reciever.
I am using a 18m2. The problem is when the pulse from the hall sensor slows and stops the servo does not hold. It seems that i can not have pulsin with a slow pulse ,with servo. I have read that the best way to do this is to have multiple picaxes. Has any one solved the issue with the "servo" pulsin" or can any one give advise about how best to send data from one picaxe to another and which picaxes are best suited for this. By the way i have also tried "count" in place of pulsin which resulted in the same problem
