As the title of this post suggest I'm having problems configuring the serial input as pinC.4 It basically does not work correctly as a digital input!
I have tried the attached code on two different chips with the same problem.
Can someone out there test this simple circuit and code to verify?
I have verified that the circuit is wired correctly and YES the download cable is removed during testing.
Using this code the LED will not come on at all.
Changing the code to:
The LED will come on initially and follow the code until pinC.4 goes high, at this juncture the LED operation is delayed.
It seems that some of these operations are trying to initiate a download which could be the cause of the problem.
Thanks to brothermenot for the schematic.
Steve G
main: if pinC.4 = 1 then LED_on
LED_on: high B.0
pause 500
low B.0
pause 500
high B.0
pause 500
main: if pinC.4 = 0 then LED_on
LED_on: high B.0
pause 500
low B.0
pause 500
high B.0
pause 500
Steve G
