When the PICAXE-08 first powers up, all pins are configured as input pins (except
pin0, which is always an output).
All pins are configured as inputs on first power-up (unless the pin is a fixed
output).
Some microcontrollers allow inputs to be configured as inputs or outputs. In
these cases it is necessary to tell the microcontroller which pins to use as inputs and/or outputs (all are configured as inputs on first power up).
Many PICAXE microcontrollers allow pins to be configured as inputs or outputs.
In these cases it is necessary to tell the microcontroller which pins to use as
Note that ‘run 0’ is not the same as the ‘reset’ command, as the reset commandwill also reset all variables and convert all pins back to inputs.
whilst the PICAXE chip initialises upon power up. During this
short initialisation period the drivers are not actively driven (ie they ‘float’
