Hello everyone,
I'm wishing to use a 14m or 18m to do the following things.
1) Use a push button to change state of an output.
2) Store the state of an output in "memory" so that when the power is switched off then back on, the chip retains the states of the inputs. Using only the picaxe chip.
No.1 is not a problem, No.2 now that's the problem.
I've checked out WRITE command in manual 2 page 218, and this is EEPROM so should be safe on power down/up
Could someone suggest some code on how I would go about this please
TIA
TIA
