08M2 PV MPPT Charge Controller
Solar Mike
Have been building solar PV charge controllers for many years, thought this project may be though provoking for some readers on this forum, designing an ultra basic controller using a 08M2, usually I post all my projects on "TheBackshed" forum and will continue to so so as they allow more images etc in posts.
So rather than repeat everything here, will add a link for anyone interested. Picaxe PV Controller
Have just sent the gerber files away to get pcb's made, so will be a couple of weeks before I get them back and can start writing some software.
24176
Cheers
Mike
lbenson
Very interesting design. I had read the linked TBS thread when originally posted, and noticed that you said that because of a shortage of pins on the 08M2, "Cannot measure the PV voltage, will have to improvise using software to determine PV is present".
I was wondering how you were going to do that improvisation, but see now that an additional design you posted in that thread uses the 14M2, which seems like it might be less restrictive. Do you still think the 08M2 will do what you want?
(Writing in Nova Scotia, not quite 45 degrees North, where there sadly seems no hope for solar.)
Solar Mike
With the 08M board, PV must be present if at 100% PWM, there is charge current detected...
Don't really care about the PV; all I want is max charge current for any solar variations, so mppt operation will be optimizing the PWM for max charge every second or so.
This project needed to small as possible, but should work ok, need 10 or so minimal functionality controllers for some remote batteries out in the field.
Added the 14M2 to get some extra led status indicators.
You must get some sun....
Cheers Mike
AllyCat
You can also use C.0 of an 08M2 as an ADC input using READDAC{10}. It can be particularly useful for reading bi-directional currents as the DAC can introduce a bias. But I would consider 08M2 v 14M2 irrelevant for a circuit design of that complexity.
I'm not sure about "no hope" for solar at 45N. We have substantial solar farms in southern UK, all above 50N, but maybe the Government got the subsidy wrong (IMHO they did). However, at these latitudes the Winter months can be a major energy storage issue, or "dead loss", depending on the application.
Cheers, Alan. .
Solar Mike
Indeed; normally I use the 20 or 28X2 versions for these controllers to make use of hardware interrupt pins and much higher 64 Khz PWM @10bit resolution.
Had a read up on the READDAC{10} command, interesting...
Cheers
Mike
lbenson
I walk out my back door in July and August and think, "I'm in Paradise". But winter is a long slog, and spring? Ha, what's spring? I was raised in Virginia, where March has many nice days, and April and May and into June are lovely before it turns brutally hot and humid. When this used to be my summer home, my neighbor would say I brought the good weather up with me at the end of June.
I can't see solar doing much here, even aside from the fact that you'd want perfect placement, which I don't have.
premelec
@Solar Mike - thanks for bringing this up again! I admire your work on this while also noting that with many installations you can get pretty close to maximum power by measuring temperature and voltage of the PV panels - controlling current loading of a switching converter to keep that PV voltage in range. As PVs have become less expensive squeezing the last watts out has become less necessary though still pleasing. Using a 14M2 with 4 PWMOUTs you can, if needed, use a vernier setup where one PWM gives coarse another fine tuning of the resultant PWM signal. Mostly it isn't needed to track output by the millisecond so PICAXEs are suitable. When clouds drift by you just don't get full control...
@Ibenson solar is still working in your area despite opinions on the weather... ;-0
lbenson
Solar works--my garden did great. But PV solar in Nova Scotia? Do you have examples? Yes, there is one millionaire who fitted out his private island with solar, but the expense was great, and I'm not sure he's there in the wintertime.
Even aside from the fact that panels appear to cost 3-4 times as much here as in Australia.
premelec
@ Ibenson - glad that photosynthesis is still working to feed you &/or give you pleasure... I note that Canada has active solar PV promotion and your apparent area probably gets about 1/2 yearly KWHr/peakWatt than my area gets - that's still a lot... suggest looking at aerial views of your area to see if anyone is using PV panels. Energy storage is an on going expensive situation... this is not the best forum for a discussion. A large part is to see how to use less than NA people may be used to... end of gardening season here in a few weeks with early nasty snow storm that broke a lot of trees...
lbenson
premelec--we had our first frost three nights ago--a month earlier than last year. I'll look further, but a yearly average won't help much in January and February. No one would deny the flood of solar input in July and August.
Someone nearby has rooftop solar hot water, but in asking about I haven't heard of PV. And in any case, I'm not going to put solar panels on the roof of my 180+ year old house. I can look at an aerial view, but I could scan about 60 miles to my west-southwest without seeing even a paved road.
A "solar" cottage was highlighted recently in a news article, but they didn't mention the usage of the big propane tank visible in one of the photos.
Mike--I'll be interested to see your software, and to follow your progress (maybe on TBS).
Solar Mike
PCB's being made now, will get them back in approx 10 days.
Software I will post here, dont think many on TBS use picaxe's so will have minimal interest.
Currently looking at a suitable communication protocol to allow a master charger or aggregation device talk to the PV controllers in a small network to either send them the common voltage settings etc, or tell them to switch to Constant Voltage or Float operation at the same time; then ask each one for its average voltage or current etc.
A large bank of batteries may have 5 controllers connected; have noticed that there is always one that is the first or last to switch to CV or Float operation, ideally they should sort of follow each other closely.
I have a small matchbox sized pcb designed about a year ago that allows an isolated 1-wire connection to each device; probably will use some customized bit-bang method to send the info back and forth, just yet to decide how to do it, there is a mixture of CPU's so not all have sophisticated receive buffers etc.
Any ideas welcome...
Cheers
Mike
papaof2
I've been "dabbling" with solar for several years, primarily as a "Wait until daylight" option for the frequent but usually short grid outages we have and I've tried a number of commercial solar charge controllers - PWM and MPPT - some are much better designs than others. I'm interested in how "real world" usage works for your design over time.
The solar irradiation for Atlanta works as a rule of thumb for 50-100 miles out from there so we basically have 3 useful sun hours in winter and 5 useful hours in summer. The current system is a 12 volt, 420AH battery bank which is kept charged by a single 250 watt panel via an MPPT controller. With a 2000 watt pure sine wave inverter, the system powers fridge, freezer, a few LEDs and the internet for 8-10 hours - long enough for a storm to pass or until daylight and I could then go out to set up a small (1600 watt) inverter generator. The average running load is under 300 watts but you must allow for the surge watts of starting motors (fridge, freezer, etc.) which is typically 5 to 7 times the running watts but can be 10 times the running watts.
Finding a good place to put solar panels can be difficult when you have tall, old growth trees but this year's tree work includes removing a dead maple, cutting dead/damaged limbs on multiple trees and removing an oak that doesn't provide useful shade for the house. When the oak is gone, I'll have space for 1500-2000 watts of ground-mounted solar panels and we could grudginly manage with that for the long term - but still better than being in the dark ;-)
We'll never produce the amount of power we use from the grid (monthly utility details kept in a spreadsheet for more than 15 years) but another spreadsheet tells me what we can power and for how long on days with and without sun. If you want heat, use gas (LP, natural) or wood. Solar PV is not a good choice for electric heating.
I experience "solar envy" when I pass a design/contructionbusiness a few miles from us - the roof is covered with about 100 panels of estimated 250-300 watt size. I'd like to see their entire setup...
Solar Mike
It should be mentioned that building a mppt controller will have little advantage over a basic pwm type when the PV panel voltage is closely matched to the battery and the output power is not so high. I am only suggesting a mppt design here for my setup, which has various individual batteries using a number of differing panel types with various power outputs and voltages.
If I was building a small system and purchasing new PV panels, then basic pwm is more cost effective, as its not so complex to design and off the shelf chargers are reasonably inexpensive. PV is so cheap now that any power lost in PV-Battery mismatch can be made up by adding a another panel.
This charger could easily be turned into a PWM type if desired by shorting out the buck inductor, removing the input electro and most of the output electros.
For a larger system where we are working with charge currents > 100 amps, MPPT has many advantages is that the ripple current as seen by the battery is very low and easily controlled by software. It is not the best practice to send huge pulses of current into lead acid batteries to keep them topped up in float state as would occur with a high power PWM. The lifepo4 batteries that I mainly use probably couldn't care less about that situation, their internal impedance is so low, it would have little impact.
"papaof2": I run my home office + 1 fridge and an upright freezer off a 12v 400 AH Lifepo4 battery (4 x 3.3v cells in series) coupled to a highly modified 3.5KW inverter, 1Kw PV. its not uncommon to see surge currents >100 amps when a fridge turns on, most commercial inverters 2Kw or less would fail I think if the fridge and freezer switched on at the same time; if you want to use a low power inverter then a low frequency type is better suited as they can cope with large surges better than the HF type.
Cheers
Mike
