On the veroboard or schematics?Hi,
Your code, and a picture of your circuit/schematic would be appreciated.
Have you tried the "working" 08M2 on both veroboard circuits?Is there any way of meassuring the sound pin on 08m2 with
an voltmeter? i have two equal crcuits each with the same
chip but one fails on sound output?
Yes i have sevral of the same chips since i first try the circuits on a exepriment board before so,lderingHave you tried the "working" 08M2 on both veroboard circuits?
Does it only make sound on one veroboard and not on the other? (veroboard fault?)
Do you have 2x 08M2 chips that you are testing?, maybe one is not programmed correctly?
Once again, you should try both chips on the "working" veroboard to prove if your board is wrong, or if the chip is faulty/not programmed correctly.
Aaaha thanks wery much =)Just use high/pause/low/pause in a loop on the pin, you can then test with the voltmeter. It doesnt matter if the piezo is still connected when you do this.
