Hi there.
i am trying to make a RGB light using LED's. i have two main 08m chips that have the programs that controls three other 'slave' 08m's. the main chips have a serial out commands and the three 'slaves' have the serial in command, which takes the data in and does a pwm out. however, to make it work i need to put a LED between the input signal pin of the slave and ground. no other component will work. here is the code i am using:
fade: let b1=85
let b2=170
let b3=255
loop1:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
if b1=0 then goto loop2
goto loop1
loop2:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
if b2=0 then goto loop3
goto loop2
loop3:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
if b3=0 then goto loop4
goto loop3
loop4:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
if b1=255 then goto loop5
goto loop4
loop5:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
if b2=255 then goto loop6
goto loop5
loop6:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
if b3=255 then goto fade
goto fade
this is the program that i have in my main chip and it is supposed to fade the three led's that are connected to my slave chips.
this is the program for my slave:
input 4
serin 4,N2400,b1
pwmout pin2,b1,100
pin 2 is connected to an led.
my main problem is that the two chips are not talking to eachother properly. is there something wrong with my programme or the hardware?
cheers
pete
fade: let b1=85
let b2=170
let b3=255
loop1:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
goto loop1
loop2:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
goto loop2
loop3:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3-1
serout 4,N2400,(b3)
pause 20
goto loop3
loop4:let b1=b1+1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
goto loop4
loop5:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2+1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
goto loop5
loop6:let b1=b1-1
serout 0,N2400,(b1)
let b2=b2-1
serout 2,N2400,(b2)
let b3=b3+1
serout 4,N2400,(b3)
pause 20
goto fade
input 4
serin 4,N2400,b1
pwmout pin2,b1,100
cheers
pete
