08M Programming
dogiewal
Just downloaded the new programming editor after deleting the old one. NOW I CAN'T PROGRAM AND RUN MY 08M PROGRAMS?? HELP
eclectic
Please describe the "symptons".
No editor?
Doesn't recognise chip?
Comport error .......................................
e
dogiewal
No editor?
e
Yes, like I said, I just downloaded the new editor. Now there is no mention of the 08M in the choices the editor provides, so if I try to download a program to my 08M, the editor tells me I'm using a 20(something) editor and my chip is an 08M therefore the editor and the chip don't match. Again, there appears to be no 08M choice on the editor.
russbow
Add the line
#picaxe08m
to the top of your programme and try again.
OR, go into the option -> mode whilst in the PE, and from the drop down menu, select 08m.
I prefere the first choice.
MartinM57
I can't explain why you don't see 08M in the PE (where are you looking?)
The preferred way (should be mandatory IMHO) of indicating the PICAXE you are using is
#PICAXE 08M
at the top of your code. Try that....
Andrew Cowan
Have you tried doing a hard reset?
- Disconnect the power to the 08M
- Hit 'Download program'
- Wait for the progress bar to appear
- Reconnect the power to the 08M
08M Programming problems
It is something specific to your installation and not a general problem.
If you cannot see the 08M in the list of PICAXE devices within the Programming Editor Options/Mode display then the PE install may not have worked correctly or fully with the 08M compiler file missing.
Have you tried to re-install the V5.3.6 P.E. ? :confused:
