<i>
picaxeter penned:
do you have more info on circuit? </i>
Here is an updated schematic for expanding a picaxe 08M using one wire with a LCD interface and six auxilary outputs.
<A href='http://www.user.dccnet.com/wrigter/picaxe/1_wire_LCD2.gif' Target=_Blank>External Web Link</a>
The 1 wire 15 bit SPI design has sufficient number of output pins to control a character type LCD in the 8 bit mode to optimize for speed and simplified code.
It uses an novel LCD control interface that generates the E signal automatically at the end of the 16 bit "shiftout" routine.
The listing below includes typical LCD initialization and displays a short message on a 2 line LCD.
<code><pre><font size=2 face='Courier'>
'08M 1 WIRE LCD CONTROLLER
'wilf rigter (c) Jan 12, 2005
SYMBOL get = b9
SYMBOL byte = b10
SYMBOL dataOut = b11
SYMBOL bitNumber = b12
SYMBOL pulse_width = b13
SYMBOL PWMDATA= 1 ; Pin1 1 Wire Dataline
SYMBOL xword = w0 ; hexport word
SYMBOL xlbyte = b0 ; hexport LSB
SYMBOL xhbyte = b1 ; hexport MSB
PowerOnReset:
Initialise_hexport:
xword = 00 ; 595 Output Register STARTUP
state
HIGH PWMDATA ; initialize PWMDATA state
PULSOUT PWMDATA,10 ; initialize 595 Shift
Register
GOSUB SendPulseData ; now update 595 Output
Register
PAUSE 200
GOSUB InitialiseLcd
; User Program Here
DisplayTopLine:
EEPROM 6,("HELLO WORLD! HELLO LCDPORT! "
FOR get = 6 TO 17
READ get,xlbyte
GOSUB SendDataByte
NEXT
MoveCursorToStartOfSecondLine:
xlbyte = 192
GOSUB SendCmdByte
DisplayBottomLine:
FOR get = 19 TO 37
READ get,xlbyte
GOSUB SendDataByte
NEXT
END
InitialiseLcd:
FOR get = 0 TO 3
READ get,xlbyte
GOSUB SendInitCmdByte
NEXT
; LCD Configuration
EEPROM 0,( $38 ) ; %001LNF00 2 Line Display
EEPROM 1,( $0C ) ; %00001DCB Display On
EEPROM 2,( $06 ) ; %000001IS Cursor Move
EEPROM 3,( $01 ) ; Clear Screen
RETURN
SendInitCmdByte:
PAUSE 15 ; Delay 15mS
SendCmdByte:
bit14=0 ; Send to Command register
SendDataByte:
GOSUB SendPulseData
bit14 = 1 ; Send to Data register next
RETURN
SendPulseData:
; xword / xhbyte
pulse_width=1 ; START = bit 15
PULSOUT PWMDATA,pulse_width
pulse_width=2 - bit14 ; LCD RS BIT
pulse_width=2 - bit13 ; aux output 6
pulse_width=2 - bit12 ; aux output 5
pulse_width=2 - bit11 ; aux output 4
pulse_width=2 - bit10 ; aux output 3
pulse_width=2 - bit9 ; aux output 2
pulse_width=2 - bit8 ; aux output 1
; xword / xlbyte
pulse_width=2 - bit7 ; LCD DATA MSB
pulse_width=2 - bit6
pulse_width=2 - bit5
pulse_width=2 - bit4
pulse_width=2 - bit3
pulse_width=2 - bit2
pulse_width=2 - bit0 ; LCD DATA LSB
PULSOUT PWMDATA,pulse_width ; Update both 74HC595 outputs
PULSOUT PWMDATA,10 ; LCD E pulse and clear 595s
RETURN
</font></pre></code>
----------end of listing--------------
The 4 bit LCD version is shown here:
<A href='http://www.user.dccnet.com/wrigter/picaxe/1_wire_LCD5.gif' Target=_Blank>External Web Link</a>
Edited by - wilf_nv on 06/01/2007 20:54:52
