Any thoughts on generating IR out at frequencies other than 38KHz with an 08M? I know Hippy has some ideas on line for Infrain work-around that might work on the receive side with the correct demodulator.
Only thing I can figure on the transmit side is to use pwmout to get the carrier frequency and they use another output to modulate the carrier through a FET or external mixer. I don't know if serout at an appropriate baud rate could be used.
Paul
Paul
