Here's the code for a simple test circuit to demonstrate the problem. Syntax says "49 out of 256 bytes used", OK. I want to store numbers in the remaining eeprom locations starting with #49, OK. If I write line #9 to say ( if b0 = 255 then send ) the circuit will not operate correctly. It only works if the value of (b0) does not exceed 207, which also happens to equal 256 minus 49. This leaves only 158 eeprom locations available. Why can't I use all 207 remaining locations in this application and what happened to locations 208 through 255 .
Thanks,
Steve G.
Thanks,
Steve G.
