peter howarth
reading other peoples threads for hassles getting picaxes to work with common lcds, i note that back in june 1,2008, member westaust55 moderator, wrote the following:
"The picaxe manual has the wrong connections for the data pins ,( they are back to front ).. This has been raised by others in the past.."
also member DLP1 commented on problems with the picaxe manual , same date june 1 ,2008..
Well i rest my case, I am not the only picaxe learner who is having problems with the picaxe documentation from rev ed, that has turned out to be incorrect..
Whigh begs the obvious question.: what else in the whole rev ed documentation is incorrect ? ! well the mind boggles doesnt it..
