AND
69-cat
Is there a way to have more than 2 inputs to control an output? If I add a 3rd, I get errors with the simulator....
Dave
;2 input AND gate
if pinC.1 = 1 and pinC.2 = 1 then high c.4
else low c.4
Flenser
69-cat,
From the PICAXE manual2 the IF statement only allows 1 or 2 tests so no, you can't specify 3:
Syntax:
IF variable ?? value {AND/OR variable ?? value ...} THEN
{code}
ELSEIF variable ?? value {AND/OR variable ?? value ...} THEN
Seeing as the pinC.N values are either 1 or 0 a workaround for you is this:
bit1 = pinc.1 and pinc.2 and pinc.3
if bit1 = 1 then high c.4
else low c.4
While the IF...THEN statement uses two "tests" as an example, it does not categorically state there cannot be more.
Using three tests in the IF . . . THEN statement is working for me in the PE6 simulator
Both the code by Flenser and that I tried happen to use 21 bytes each.
Flenser
westaust55,
You are correct. I didn't look at the IF statement syntax carefully enough.
- That "..." at the end usually means that you can repeat the clause more times.
Aries
It was a "syntax" error,
Just for the record, a syntax error is nothing to do with the simulator - it is a problem with your code and the compiler (and I would put money on it being the code and not the compiler)
