JoeFromOzarks
Hello folks,
I'm using a 28X2 and wish to use the following pins (examples, across multiple ports) as interrupts in an OR configuration: (SETINT: 28X2: only inputs C.0 to C.7, B.0 to B.7 and A.0 to A.3 may be used).
A.0
B.0
B.1
C.0
That is, either A.0 OR B.0 OR B.1 OR C.0 goes high should trigger the interrupt:
How do I configure the SETINT command to eyeball the above pins? What am I missing?
Thank you!
joe
A.0
B.0
B.1
C.0
Thank you!
joe
