A question for technical - is it possible to download PE 5.2.3 to test a possible bug in 5.2.4?
I just upgraded my main machine and primary laptop to 5.2.4. I downloaded some new code on my 28X1 chip and it seems to go into a reset loop. I downloaded some known good code and the reset still happens. (It shows my startup screen, goes into a temperature monitoring screen and then resets with the startup screen showing again).
I have an ancient laptop that I use for emergencies and it has 5.2.0 on it. I downloaded some known good code (not the same code as above unfortunately) and all is good.
I'd like to go back to my last known working point to repeat the test, and that means using 5.2.3.
thanks.
thanks.
